Hi there. Thanks for taking the time. Ok, when my computer crashed without reason a few weeks ago, I couldn't turn it back on, and after trying forums, decided to get it sent in. The techie's told me the problem was narrowed down to the mobo or CPU, and it would cost at least £50 more to find out which. So I finally took the plunge and went for the newer CPU'S, and PCI-E, and DDR2 technology...sort of.
I chose the AsRock 4CoreDual-SATA2 because it was a 'half-way house' board, and I could use my older tech AGP Sapphire X1950 pro and 2x500MB of OCZ DDR PC-3200, 400 Mhz platinum RAM. They can still easily hold their own in games. I also got a 2.13Ghz core 2 Duo processor, and a top of the line Zalman CNPS9700 heatsink for overclocking headroom. The PSU is a sumvision 650W. I use windows XP professional.
Anyway, I connected everything as well as I know how. I built this PC originally a few years back, and much that I learned is now gone, but I knew to discharge static electricity by touching the downstairs PC with both hands.
There weren't any overt problems with the main cables that can only go in one place, both power cables etc..But I may have put the front panel header connections in the wrong places. Could somone tell me (or link me) how to connect PW-SW, PW-LED, RESET-SW, HD-LED, all 2 pin affairs, as well as the sound one's, such as (MIC), a one piece 7 pin connection which I think might be for USB, and an unmarked 4 pin connection. The case is an antec 160w, I can't find information about the connections from searching for my case. I have a creative Audigy 2 ZS soundcard, do I even need to make the sound connections? Are any others unneccessary?
Is the ground (GND) wire always white with PC's?, I've tried the front panel headers both ways round though.
When I try to turn the PC on, nothing happens, not even that important beep, what does that indicate?
Is there another way to turn the PC on, bypassing the front panel to know that's the issues? Could the jumpers be useful here?
Thanks a lot, I'm lost here.
