Installation Builders
31 Jan 2007
Hello,
A friend of mine is making a scenario using a scenario editor of a game, he is using a load of custom items in game and custom images and music. He has thus asked me to create an easy to use installer whcih will put the scenario file and all the custom objects, music and images into the correct folders on the users computer. Can anyone point me to an easy to use program to make an installer where I can set what files need to go into which folder on a computer.
Thanks
Neil
TBH if you're developing software that requires a dedicated installer you probably don't need a GUI interface ;)
There are GUI-based applications that can do this actually (Wise etc) but they tend to be commercial apps which cost serious moolah!
