Hi All,
I've just bought a triplehead2togo unit from one of the forum members on the MM and I'm having trouble getting it working.
The set up I'm using is as below
Windows 7 Ultimate 64 RTM
Triple Head 2 go Digital
Latest Matrox Drivers Powerdesk etc (Vista 64 versions as no Win 7 available)
ATI 4870X2
Catalys 9.8
2 * Dell 2407 A03's (Default resolution 1920 * 1200)
1 * Samsung 191T (Default resolution 1280 * 1024) (Temporary, to be replace next week with another Dell 2407)
Other components in the sig
OK, so the problem I'm having is that I can't get a fully functioning triple head set up.
The results I've had so far are
1) Monitor one with what seems to be a stretched screen displayed on it compressed so hardly visible and offset by 50%, No display on other two screens
2) Can get a triple screen set up working across all monitors at 640*480 (no other resolution can be used)
3) Both Dell monitors reporting errors asking for default 1920 * 1200 60hz feed with no display on all 3 monitors.
I've tried uninstalling and re-installing the Matrox software a number of times. When I try to install the game control software it reports that there is no TripleHead present.
TripleHead is powered through Powered USB slot and has a green light.
On checking processes running in Task Manager there are about 5 Matrox processes there.
On Entering Powerdesk and trying to change the resolution error reported that it can't change the resolution.
Within Display properties there instead of a 4870X2 it shows the graphics driver as being a Triple Head, but on trying to set up any triple screen resolution it goes into problem like (3) described above.
I can use the number one monitor (Dell 2407) at 1920 * 1200 resolution on it's own through the triplehead.
So that's an overview of the problems. If anyone can help me resolve this I'd be very grateful as I really want to start playing games across the 3 screens.
Thanks for any help
Taff
ATI 4870X2
Catalys 9.8
Thanks for any help
Taff
