Installation problems
31 Mar 2009
Stoke-on-trent
I'm currently trying to fix my brothers Sony Vaio VGN-NR10E laptop.
It failed to load the current version of windows vista installed on it (unsure why)
So having a spare copy of windows 7 i'm trying to install that.
It gets to the starting windows screen and then just hangs - I've test the memory and that's fine.
Any ideas why it wont get to the installation section?
Cheers
Is the HDD ok ? Format went ok ?
Try installing XP, I've has issues installing Win7 on old VAIOs.
well it stayed on the starting windows screen for 3 hours, then in stalled windows 7 taking an other hour. but now it boots up quickly and is working fine.
not sure why though :D
