Hi,
I've just installed a Connects2 CTVBMX003 adaptor in my e39 with stock head unit (HU).
This device is a small box that connects to the CD changer socket on the rear of the HU and provides an Aux input.
I have an issue in that the left channel is notably quieter than the right, it throws the balance out quite a bit.
I can correct it with shifting the balance almost all the way over to the left but this then throws the radio audio balance out (balance not input-specific setting).
As the radio and CD audio is still fine I am assuming it's not the wiring harness I've installed that sits between the factory loom and head unit.
How would you go about pinpointing the issue?
I could test the resistance in the cables from the Connects2 box to the CD changer plug/connector.
Do you think it's likely to be the actual Connects2 box?
Thanks in advance.
Thanks in advance.
