Installed Google Chrome,double click, nothing?
27 Jul 2008
just tried to install it on my Vista 64 bit machine and it seems to install but when I try to use it nothing happens.
Any insight would be great.
Try killing all instances of it from the task manager. If that fails, try rebooting.
(had this problem the other day and a reboot fixed it)
Does it work if you tried running the exe file instead? It can be found in either the %appdata% folder or program files depending on how you picked for it to be installed.
