Hi,
Installed my First AIO, Arctics Freezer 3 240m. Rally impressed with the Cooling and noise level so far. however what Setting should i change in Windows, software or my Bios for this?.
so far the PC feels maybe a little less speedy than before and ive had abit of a hang at the start of windows launching it from a cold boot 2nd time round which has never happened before
Squeezed this monster into a SSUPD Meshilious using slim fans. i'd really not recommend it, was Fing Hard work! it but it fits! it however is much cooler, even 10 degrees cooler than my air cooler at idle and almost silent which is amazing.
btw i am using the single lead to the CPU fan header not the three seprate ones. didnt see the point but open to any advice if it makes a difference!
Thanks
Paul
![Eek! :eek: :eek:](/styles/default/xenforo/vbSmilies/Normal/eek.gif)
Thanks
Paul
