hey all, i installed the new case i got today (Zalman Z9 Plus)
everything went fine with installing the parts, when i put the power cable in the power LED lit up and when i tried the switch and pushed it nothing happened, so i fiddled around for a while the pc booted by itself when i put the mains cable in the PSU and when the PC was on and running the switch still wasnt working? but the LED in the switch was lighting up, the HDD light was working and the switch is in the right slot in my mobo, also im now having to use my old pc front pannel switch to turn it on and off, also its not the psu as the paper clip trick works every time... also when i use my old front pannels switch and plug the fan controller in that doesnt work either, its just the fan controller, the temperature monitor works fine and im guessing the USB ports and audio jacks work fine, ill try them soon, but what should i do?!?!?
the case only arrived today and i dont want to have to RMA the WHOLE case as it cost £10 to get posted here, and also the Pannel with the usb ports and fan controllers etc. is removable as one small unit and the switch is unpluggable and tiny, so can i have OCuK send me another fan controller unit and switch without having to send the whole case back as it would be cheaper for us both and this is my first buy from OCuK and i ddont want to be let down by them?
what can i do?
Many thanks!
what can i do?
Many thanks!
