- 2 May 2023
- UK
I received a rx7900xtx today. Upon installing and attempting to boot the pc, no signal is sent to the monitor. I previously had a rtx3070. I used DDU to remove the drivers for it, shut down the pc and then installed the new gpu. The cables are connected securely and all the fans are spinning on the gpu. It only boots to safe mode. Othwise the screen stays boack. I'm using a display port cable that was working fine with the previous gpu. My specs are as follows: cpu: ryzen 7 5800x3d. 16gb corsair ram at 3200mhz. PSU: Seasonic prime gx-850. Motherboard: asus prime b450f gaming. I installed the most recent bios update when I installed the Ryzen cpu. Thank you for the help in advance!
