Installed Win7 on a Partition I can't boot from ! (help please)
20 Aug 2006
complicated a bit ...
but split a drive into 2 partitions
then installed Windows 7 RC onto one of these .. .it installed fine - rebooted during the process (as per normal installation) - installed my software etc ... all fine
but when I went to boot the next day - I realised that I'd installed Windows 7 Beta on the other partition .. (on same drive)
I press F8 to choose boot drive - choose the drive - but the partition with W7 Beta seems to have priority ...
I know it must be technically possible to boot to the other partition as the W7 installation process managed it - just can't fathom it out.
tried editing the boot loader (can't remember the software I used) - for the Windows 7 beta (which I can boot to) - to add a Windows 7 RC option .. but didn't work :(
any ideas please ?
RC should have priority because was installed later :confused: should've overridden beta's bootloader IMO.
Boot from Windows disk and format beta partition/repair RC partition, either/both should do the trick.
