Permabanned
- 9 Sep 2010
Installing a Radeon 4870 right now and bumping into a few problems. After install takes twice as long to get signal on moniter, to the point where you can press del to enter bios, writing all slightly blurry, then there's two strips down the centre at the XP loading screen, where a lot of the pixels are white. After XP loading screen when desktop would normally load the screen goes black and theres white squares all over the screen!
I have no idea why have to use internal GPU to write this! Any help would be appreciated. Swapped this 4870 for a 5670 with a friend as he wanted DX11 now playing games on internal GPU which is ****e!
Rest of setup is as follows:
OCZ 600w Stealth Stream
Biostar GF8200e Mobo
AMD Athlon2 x 4 2.8ghz
2 GB DDR2 Ram
CDR/DVD Combi
Sata Harddrive
Please help!
2 GB DDR2 Ram
CDR/DVD Combi
Sata Harddrive
Please help!
