Eek! Just fitting my 5820k into my motherboard. I'm pretty sure I have it in the right way - eg. lining up the little triangle top right. And the tiny hole at bottom right - but when I got to clamp it in there seems quite a lot of pressure on the first clamping pin. At an angle of 45 degrees from the board there's already quite a bit of resistance, and gently pressing further I can hear a very light.. sound - I don't want to say crunching as that sounds too dramatic - but kind of!
Is this normal? Is it normal that there'll already be quite a bit of resistance when the clamping pin gets to 45 degrees??
This is always my least favourite part of a build and I don't want to screw it up!
Thanks.
Thanks.
