Hello guys
I am building my first rig in long time and need some advice on fans.
My case, Corsair 200R Compact can accomodate up to 8 fans of which 5 can be 140mm. I decided to go with 5 140mm fans and 1 120mm, with blue leds - it fits my systems colour theme (Black / Blue).
Its not very powerful system and no overclocking done yet, so I am looking at low rpm and quiet fans.
This is what I would like to instal:
5x140mm Blue LED fans:
http://www.overclockers.co.uk/showproduct.php?prodid=FG-001-AE
They would go 2 on top, 2 on the side panel and 1 at the bottom near PSU.
1x120mm Blue LED fan:
http://www.overclockers.co.uk/showproduct.php?prodid=FG-003-AE
It would go at the back of the case, replacing the Corsair stock fan supplied with the case (which is plain black).
I will be also adding a controller:
http://www.overclockers.co.uk/showproduct.php?prodid=BB-001-ZA
Now, I didnt instal fans before, ever, and I have seen many comments on intake and exhaust and good airflow. I am a bit confused with all that information and need some help with installing those fans into my case:
http://www.overclockers.co.uk/showproduct.php?prodid=CA-107-CA&groupid=2362&catid=1489&subcat=
Hope to hear from you soon
Bart
Bart
