Ok, im skint and my pc is hot, i have a drill. and a hot wavemaster but, what i need to know is;
If i drilled 4 holes for screws then in the space where the fan would be placed drilled loads and loads of holes kinda like the front of the wavemaster would this work as a decent way of getting air in? and how would the fan be secured would it be
4xscrew>4xholes of aluminum>screws go though holes on fan>bolts on the end.
