Hi guys,
I've bought a dashcam, an "add-a-fuse", and the cable which reduces the voltage. Now it's a case of installation...
- I can run the wire from the dashcam to the headliner but when I get to the A pillar I really want to hide the wire. Is the A pillar on the Golf difficult to remove? Would you recommend an amateur simply has the small amount of wire visible (from roof to door seal)?
- The installation guides I've seen all run to the fusebox behind the glovebox. The only problem with this is I have an airbag switch on the side panel which none of the installation guides have. Should I avoid removing this panel and use the drivers' side instead?
