Installing a Titan Fenrir EVO CPU Cooler with a OC kit
26 Jun 2009
Ok all my stuff arived today i got the Krypton Intel Core i7 950 3.06GHz @ 4.00GHz Overclocked Bundle just ot to ask as i thaught it was all set ready to go but do i remove the backplate ? I Thaught OC pakacges were ready to bo buttheres still a silver backplae is that ment to be there or does the backplate that comes with the Krypton Intel Core i7 950 3.06GHz @ 4.00GHz Overclocked Bundle get install to sit right on the MB ?. Sorry i cant get my camera to take a photo but b4 i isntall the coller makign sure if i have to remove this or not ?. Im guessing not as surly it will make the bay for the i7 very loose and will fall out ?.
Thx in advance for any help
Hi there,
Our bundles do not ship with the coolers attached as this makes the bundles difficult to ship and more prone to damage.
There is nothing you need to remove from the motherboard to fit the EVO cooler.
The cooler will have a backplate with 4 prongs sticking upwards, put this under the board and slide the prongs through the 4 mounting holes around the CPU socket.
The apply your thermal paste (thinly) onto the CPU and place the EVO heatsink ontop.
Once you have done this place the "I" shaped bracket throught the centre of the heatsink and link up the holes with the prongs from the backplate.
The screw in the thumbscrews (only a little at a time each) into the prongs from the backplate. Once you have done this and their is no wobble, the cooler is attached. Now you just need to attach the fan to the heatsink with the provided clips.
The easiest way to do this is to attach one side of the clip first and then hook it onto the fan and then hook the opposite side around the heatsink, thus attaching the fan. Plug the fan into your CPU mobo header and you're done!
Also please use a spell check or something.
cheers thanks thats what i thaught :) i did know about the coolers dont come shipped but didint know if i had to take of the back plate good thing i dont cheers :. i also was a total noob and forgot to order thermal paste so will be ordering that soon :). Dont trust PC worlds stuff :).
