- 13 Sep 2006
Hi
I'm needing someone to explain this to me.
I want to build a dual boot (Vista 64 Home Premium / XP Pro 32bit) system. Each OS on a separate hard drive.
So far, I understand that I should install XP Pro first, then Vista, and will get the option on booting, as to which OS to load.
What do I do with my applications? An earlier post said that I will have to install them twice. Does this mean a full set of apps on each hard drive?
I'm only going down the dual boot road because I have some software synths that don't run in Vista 64, and another couple of specialist apps that also don't apparently work in Vista.
So Advice - Explanation - Instruction - all gratefully received!
