Installing Blackmagic Drivers
10 Jan 2009
London
Sorry to be a pest but i really need this hardware installed and Ubuntu keeps giving me errors everytime i try and install either the Decklink drivers or the Media express software
They are the latest drivers from the blackmagic website.
The error i recieve is
There seems to be a programming error in aptdaemon, the software that allows you to install/remove software and to perform other package management related tasks. Please report this error at http://launchpad.net/aptdaemon/+filebug and retry.
thanks for your help
No idea but I'd make the following suggestions/points/etc
- what version of Ubuntu?
- is it patched up to date?
- do you have all the pre-requisites for the drivers installed as per the readme?
- are you that your downloaded deb file is not corrupt?
- what is the command and exact output you are running when the error occurs
- kernel version?
- kernel version?
thanks for your reply
- it is ubuntu 10.10
- it is fully up to date
- the read me just states to run the correct driver file for your version of linux in my case it would be the .deb files.
- i downloaded the drivers twice to check and still got the error upon execution
- i just double click the driver and it opens in the ubuntu package installer and then the error occurs once i click install
- 2.6.35-24-generic-pae
I'd possibly try the command line installation method as given in the readme (for Decklink at least) to see if it gave any other information about what's going wrong.
Regarding pre-requisites the readme file does say that you should have the following installed:
* dkms
* opengl (recommended)
* kernel-headers (or source) (for currently running kernel)
* gcc, make
* glibc 2.8
Depending on your install options you may not have all of these, (although if you do not have them then I would expect the installer software to give a dependency error instead of just falling over.
* dkms
* gcc, make
* glibc 2.8
i will give it a try and where did you find these install notes, they did not come with the package i downloaded?
here are the details for the error code i get when installing if it helps
Traceback (most recent call last):
File "/usr/lib/python2.6/dist-packages/aptdaemon/worker.py", line 768, in simulate
return self._simulate_helper(trans, status_path)
File "/usr/lib/python2.6/dist-packages/aptdaemon/worker.py", line 851, in _simulate_helper
size = int(deb["Installed-Size"]) * 1024
ValueError: invalid literal for int() with base 10: ''
Yeah finaly done it thanks for the help, especially with thats readme.
iin the end i had to downgrade dpkg to an older version to get the drivers and media express to install. alls good now.
thanks again
