installing bt broadband-pls help
14 Aug 2003
cyberspace
hi,
I can't get my bt broadband install cd to work under windows vista. is there any other way to get bt broadband working?
Go to the BT website, log in using your username/password and look at the sotware downloads section. Not sure what you are wanting form the CD, but you should be able to manually set-up the home hub, and you can access the 'free' software such as Mcaffee etc through the website.
