Hi all
I built a new PC yesterday, but im not sure if ive positioned the fans correctly. What I mean is, which way do you have to position the fans for them to work as exhaust or intake ?
I thought that for exhaust, the logo must face the inside of the case, is this correct ?
If it helps, I have a coolermaster CM690 case (ignore specs below as they are from my old system)
