- 6 Feb 2008
okay so i just brought a Creative Sound Blaster Audigy from an amazon seller
put it into the PCI port and rebooted computer and nothing happened, no new hardware detected or anything
tried to install the drivers that came with the card and they it told me the card is not installed and to rerun the setup when i've installed it
wiggled the card around a bit and securely screwed it into the case but still no joy
had a look at guides on installing cards and many of them mention connecting cables from the cdrom drive to the card
also on the card there are 2 slots that look like wires should be attached to them:
(the little black port that has "aux in" next to it and the white rectangle that has "Sound Blaster" above it(both on the top right hand side))
do i need more cables or is my card just broken?
thanks in advance
thanks in advance
