Hi,
I just bought the Aerocool CS-1101 case. https://www.overclockers.co.uk/aerocool-cs-1101-midi-tower-case-black-ca-194-ae.html
The product listing says it comes with an 80mm fan at the back (it does), it can take a 120mm fan at the front, and it can take 120mm or 140mm at the side. So I bought a 120mm fan for the front and a 140mm fan for the side. But I can't see how to install the 140mm fan..
There are 8 mounting holes on the side radiator:
1____2_3____4
5____6_7____8
The 120mm fan screws line up with 1,3,5 and 6 (or 2,4,6 and 8). I haven't opened up the 140mm fan yet but can't see how I'd install it based on these mounting holes.
Am I missing something obvious here?
Thanks,
Owen
1____2_3____4
5____6_7____8
Thanks,
Owen
