Installing gapps/rom
17 Jun 2012
I don't have an sd card and the twrp I've installed only allows for adb or sd card although I have seen twrp version that seem to allow to install from internal storage.
Firstly I assume you can't install a rom via odin?
I'm going to try the adb method but also need to install gapps, do I just install gapps in the same way as the rom and after the rom is installed?
It's
adb sideload "C:\yourROM.zip"
I think.
Also don't I completely erase the phone first in twrp or just the caches?
