29 Apr 2009 at 19:53 #1 Izi Izi Soldato Joined 9 Dec 2007 Posts 2,718 Is it possible? I have SQL server 2000 Standard installed. I want to install 2008 standard as well, but leave 2000 as it is. Is this possible? Would i have to specify different ports for each installation?
29 Apr 2009 at 23:36 #2 iaind iaind Soldato Joined 26 Feb 2009 Posts 14,817 Location Exeter You should be able to specify it as a different instance (eg [servername]\[instance]) but I very much doubt its supported. VMs may be a better option here?
30 Apr 2009 at 00:27 #3 Stelly Stelly Don Joined 5 Oct 2005 Posts 11,241 Location Liverpool I dont see why not, I run 2 x 2005 instances, 1 x 2000 instance on one box Stelly
1 May 2009 at 15:30 #4 svbooga svbooga Associate Joined 1 Jan 2006 Posts 191 no problems running multiple versions as long as they are on seperate instances, we do it here for development.
2 May 2009 at 13:15 #5 sparkey196 sparkey196 Associate Joined 3 Jun 2008 Posts 411 I can also attest to it working. I have 2005 and 2008 installed on the same box.
