Hi guys,
I'm in the process of installing my computer with all of it's components...this is the first time I've built a computer so I'm a bit confused and nervous just in case I mess up.
Anyway, I've installed my E6600
and now I'm installing the Thermaltake Big Typhoon and the instructions aren't helping me.
First, I wasn't sure which way to fit the sponge, I've done it now hoping it's in the right way (I think it is) but now it says:
"apply a thin layer of thermal grease on the CPU die"
What's the CPU die?
and is the thermal grease the same thing as the heatsink compound which looks like PVA glue?
Thanks in advance and no doubt I'll be back very soon with more questions
and now I'm installing the Thermaltake Big Typhoon and the instructions aren't helping me.First, I wasn't sure which way to fit the sponge, I've done it now hoping it's in the right way (I think it is) but now it says:
What's the CPU die?
I normally put about a pea size amount on the CPU and the flatten it out with the back of my nail (Personal Preference
