Installing office 2007 on Sumsung NC10 Netbook
13 Oct 2008
Hey all. I just got the samsung NC10 netbook and am attempting to install office 2007.
I had the office 2007 on a cd, so I copied the files off the cd, to usb, then onto the NC10 hard drive. But when I try and run the setup it throws up a dos box that disapeers as soon as it appears, then does nothing.
From running it through dos, I get the error "Program to big to fit in memory".
Now the Ram is 1GB and the virtual is max at 3GB and there is no additional programs running. So I cant understand why memory is an issue.
Any help. Much appretiated.
Thanks
Try ripping the CD as an ISO with something like ImgBurn then mount it with Daemon Tools. It'll run it as if it was a proper CD rather than just executing the files.
