I've been trying to install Ubuntu onto a flash drive, so I can use my ancient laptop again (HD died, IDE drives are stupidly expensive)
But I'm having trouble installing it from windows. The Ubuntu guide mentions using usb-creator.exe from the image... I've mounted it and can't find it (using 10.04.1)
They also mention I could use Unetbootin to create a bootable USB drive, and that has works, but it seems to be functioning the same as a Live CD, with the option to just run it or install, though I can't install to the flash drive. I also tried toe universal USB installer, with the same result, its acting like a live CD.
Is there a way to create a bootable flash drive that has its own self contained OS on there? Not one that has to be run live, I'd like it so changes would be saved to it, and so on. I know it won't be super fast over USB 2, but it doesn't need to be.
Edit: Actually, would Ubuntu even be the best choice for this? I picked it because its the distro, at least from my limited knowledge, would have the least compatability issues.
