Installing original bios?
20 Mar 2006
Nottingham
Hi does anyone know how to install the original bios back over a newer version?
I have the asus a8n sli deluxe and updated the bios - but now it wont let me push the volts as high as it used to?
so now i want to revert back to the original bios - how do i do this?
cheers
IIRC the ASUS utility won't let you go back to an earlier BIOS, so you have to go the floppy route.
Dunno what would happen if you re-named the older one and did it via the ASUS utility.
The floppy route is http://www.bootdisk.com/ (Driver Free Disk For BIOS Flashing ) then look at the manual.
I wanted to restore a previous bios on my Premium, after updating to 1009 from 1006 i couldnt overclock. Flashed to 1006 from dos and still couldnt overclock. So i reset the bios with the jumper and all is fine now. Just try reseting with the jumper it might revert back to a previous version.
I have already tried that mate, unfortunately that didnt work! also i dont have a floppy drive... any other way of getting the bios on a removable storage and booting off it?
Yup.
Make a bootable CD like this.
hi i had the same kind of problem on my a8n sli deluxe wanted to update the bios to try and sor a problem with the onboard audio and pcislots (audio not working and when i install drivers for a pci device it shuts my comp off). i fount that i have the latest beta (1017-004) anyway i want to put it back to the 1016 bios but hav no idea how to do it i tryed doing it the floppydrive way but it wont let me downgrade any ideas?
