Hey dudes,
I'm a complete novice when it comes to DIY, and I mean that.
I've just purchased a hammer drill in order to install some shelves in my bedroom, which will become a bookcase. I'm just wondering what type of fittings i'll need? http://www.bigdug.co.uk/shelving-c2...slot-wall-mounted-shelving-components-pp14314 These are the brackets i'm planning on using, but what type of rawl plugs/screws do I need, my walls are really crumbly plaster on brick; I previously installed a can crusher in the kitchen and the walls were so crumbly when I used it I ripped the entire thing off of the wall (although that was probably my fault). The shelves will be roughly 84inches long and supported by 4 uprights.
Thanks in advance
Thanks in advance
