I simply moved it to the hole above the little tab on the bottom as this broke on mine as well, once the wires are under tension holding the fan itll be fine. Tbh im not a big fan of the wire clips, may replace them with the fan shrouds.just realised the little bar that holds the fan wires has snapped off on one side,what can i do to attach a fan on it?!
