Installing Visual Web Developer 2005 Express
16 May 2005
I'm looking to develop ASP.NET 2.0 stuff off my XP Pro Machine. Anyone had any problems or pitfalls with this as it's a bigish dl & installation and I don't want to go through the hassle of setting it all up if it's gonna cause problems when I could just use DW?
I haven't got IIS running on this machine and while I intend to use a remote host for sites, I used to find when I started with old ASP on my NT4 machine it was great to test locally. Especially as I seem to have to ask the host to enable me to folders to be written to from the ASP.net!
Will I have to start logging in to the machine?
vwd2005 comes with a mini webserver, which you can setup to use random ports, so you don't have to install IIS at all. However once you get started I recommend you move to IIS, as this will reduce problems when it comes to deployment for the final enviroment.
I develop both 1.1 and 2.0 (both 64-bit) on the same pc with out any issues, so it seems to fairly robust.
If your unsure why not use vmware (they have a free beta program atm), so you can keep everything isolated.
akakjs
