I am thinking of changing my current case to a Thermaltake Armor VA8000BWS and installing water cooling. Could anyone who has done this, tell me what radiator you used and where you put it?
At the moment I am only cooling the CPU and board using 1/2 inch Danger Den blocks, Black Ice GT Stealth120 radiator, Aqua Res and aDDC-1Plus pump. I was planning on swapping the res over to a bay res and maybe adding a water block to my graphics card at a later date, so will be swapping my rad over to something a bit larger. Any help or advise would be greatly appreciated.
Any idea how loud this will be with 3 120mm fans and the 90mm fan running?
