Hi,
I'm getting really desperate for some help with my HTPC.
I have just purchased a Hitachi Deskstar 3TB HDD with a view to partitioning it as 80GB for the OS and the remainder available as storage for movies and other media.
Having researched it all I should require as an EFI enabled motherboard, Windows 7 X64 and the drive set as GPT rather than MBR.
Note the requirements differ if you are running a 32 bit OS, or adding the drive as an additional storage only device.
My motherboard is the Gigabyte GA-A75M-D2H this as an AMD (FM1) Llano chipset which is EFI enabled.
The BIOS or rather EFI happily reports the HDD as 3TB.
Unfortunately I've been having a major drama getting Windows 7 (X64 ultimate) to play ball.
Initially it insisted on creating a 2TB partition then another 800GB one and using MBR to do it. I was unable to expand the partition beyond 2.2 TB.
So I thought I'd use GetParted (linux boot CD) to set the partitions the way I want. I changed to using GPT, created my single 80GB partition and set the remaining ~2.8TB as another partition for storage.
Went through the motions of reinstalling Windows, it sees the partitions but can't install to them because (of all reasons) they are using GPT - which is what I have to use and Windows claims to support!!!
I went back into Getparted, deleted all the partitions but left the drive as GPT and the full 3TB as unpartitioned space. Windows installer sees the full size and is able to install to the unparitioned space (remember the drive is still set as GPT). However when installation is complete the drive is limited to ~2TB of space and I can't partition/format the unallocated space into anything useable.
If anyone can help I'd really appreciate it, all I want is an 80GB OS partition to boot from and the rest set aside for storage!
