This is a copy and paste from another website
"NO INSTRUCTIONS! No friggin instructions! Really, this is inadmissible. For one thing, it won't work with IDE drives unless they are jumpered for master, and for another only the *middle* sata port allows IDE drives to be detected. If you connect it up via the other sata port, you'll probably just assume it's broke."
and also
"To allow me to use an old IDE hard drive and IDE DVD drive with a new SATA based motherboard I purchased two of these devices. I am pleased to say they worked straight away. My only complaints are the very tiny writing on the board identifying the direction of the SATA connectors (one for each direction) and the sloppy fit of the molex connector pins on the power adaptor cable (trying to get all 4 pins lined up to fit the mating half was very tricky)."
From that, I see the drive has to be set on master for it to work and the converter has more than one sata connection on it, some which will work with IDE drives and ones that wont.
Not sure how to discribe the middle one which was suggested. I seem to read it only has 2 connections so not sure what middle means.
#1 If it has more than one sata connection try the other one.
#2 Also look on the drive itself, it should explain what the pins on it mean. With a little picture or some text above the pins. You need the two connected for 'master'.
This is guess work, but reviews seem to suggest it works, but can be a bit tricky to get working!
