Hi folks.
Well I've been given the task of fixing a relatives laptop, it's completely screwed over with viruses and is running slower than a Cyrix MII on 16mb of ram.
No problems, just format it and resinstall windows, however, the cd drive is broken, it doesn't do anything, it'll eject, and that's it, it won't spin up, the laser doesn't move, you can't boot anything off it.
So I need to install windows off a flash drive so I can get it working, then he can use an external CD drive or we can worry about replacing the old one.
So what would I need to do this? I've been out of the loop, I used to constantly be fixing computers, but I got sick of it, so I've forgotten some of the stuff I used to know, so any advice would be greatly appreciated, as I need to ideally get this done by tonight or tomorrow, much thanks.
Edit: I've just been informed that you can't install windows off a flash drive, I was sure you could for some reason
Is there any other way to boot and install windows without a cd drive?
