Hey all,
I'm trying to install XP on an old laptop. I'm using the Samsung recovery cd that came with it. (I've had to copy the cd to a dvd as the cd/dvd drive won't read cd's.)
When I boot to dvd I get a DOS A: prompt. (This seems odd as the machine has no floppy drive...) I've used fdisk and removed the partition and re-created it making it bootable.
I then tried to format it (A:\format C: /s) but I get a "Invalid drive, or format not supported"
I've managed to copy the i386 folder to the c:\ and when I try to run "winnt /s: d:\i386" I get "Could not find a place for a swap file" and I have to exit the xp install.
Does anyone know why I'm unable to format the only drive in this laptop??
Has anyone seen this XP install error before??
I've done the Google thing and the only answers that came up where "format the c:\ again" which isn't very helpful.
Cheers in advance for your help... (If you can!!)
edit:
I have noticed the option in the BIOS to make the recovery partition deleate able. do anyone think I should slave the hdd in to my Pc and then format the whole thing, removing the recovery part and then use our VLK edition of XP (I saw trying to avoid paying for another licence!!)
edit:
