Installing XP on SATA dive
28 Nov 2002
Down the road
Ive just bought a 5150c from Dell which came with Windows MCE. Im tired of all the clutter and crap they ship on their PC's so went to format and reinstall but when I boot from the windows CD it gets to the part where it detects the hard drive, finds four "unrecognised partitions" and if I press any key to try and install the software I get a BSOD with the message:
PAGE_FAULT_IN_NON_PAGED_AREA
Ive never installed onto a SATA HDD before, are there any special requirements?
Any ideas what's going on?
Thanks
need to find out what SATA controller the hard drive uses you'll need to put the drivers on a floppy, and press F6 to install them in xp (watch for it during installation!)
Weird. When ever i have used SATA drives, there is no error, it just can't find the drive. I would look on the motherboard manufactures website and download the SATA driver.
Any SATA drives that I installed never needed drivers as drivers are only needed for setting up RAID.
Maybe things have changed for some reason even though I installed like 60+ of them last year and never once needed driver.
However, you the drivers for setting up RAID.
Maybe the new SATA2 drives need drivers due to XP being out before they were made.
i got a SATA2 drive and never needed any drivers
Only issue i had with installing a fresh copy of XP was it didnt see all 250gb.
I think you will find some SATA controllers (nForce/Nvidia) emulate IDE thus requiring no drivers for the HD's to be detected during XP install. Promise, silicon image ..etc don't do this hence the need for SATA drivers.
The drives you see are most likely a memory card adapter, probably one built into the monitor, as mine is on my 2405FPW (Dell) - chances are your monitor (presumably a Dell that came with your system) has the same.
