Hi Peeps,
I'm about to order (two) new systems for a mate + his G/F. It looks like they'll be using the ABit IP35. I've not installed XP onto a SATA drive before and I've heard horror stories about it.
So, what do I have to do?
Will the motherboard just come with a floppy disk that I can use after hammer F6 at the start of the install?
Will the F6 work with a slip-streamed XP image? (Heard problems here too)
Is it best for me to attempt to slip stream the image onto an XP CD before hand? If so, where can I grab the files?
Thanks in advance.
Thanks in advance.
