installing xp without cd/floppy
12 Jun 2007
hey guys im having problems being able to install xp, i dont have a cd or floppy drive on the laptop and cant boot through usb or network but i do have another computer and an external caddy to be able to see all the files in the drive, any help with this issue would be much appreciated
thanks
Dump the contents of \i386 onto the drive, as well as a standard boot disk (win 98?)
Boot the laptop
(You now have to run a memory application now thats on the boot disk, cant remember for the life of me what it is)
Then run \i386\winnt.exe to install xp
ok when i put the i386 folder into the disk and the contents of a win 98 boot disk i get the error " Windows could not start because the following file is missing or corrupt:
<windows root>\system32\hall.dll
Please re-install a copy of the above file."
How have you made the boot disk?
It might be an MBR problem, not sure how to sort this. I think you need to extract the MBR off the boot disk and dump it onto the drive.
I might be able to get you a disk image that might work
Get an adapter to convert a laptop 2.5 inch to a 5.25 inch IDE Adapter - much easier than faffing about with the caddy.
Install on your main machine... swap it out after the install gets to a specific point...
erm
http://www.defectivekit.net/2007/02/guide-install-windows-without-cd-rom-or.html
No - scratch that...
Caddy
You could remove the laptop HD and put it in a usb enclosure and connect to your pc.
Format that with /s
then copy the contents of the install CD to the disk.
put said disk back in laptop and install. This has the benefit of having windows detect the laptop hardware instead of the desktop.
Unless it's an old laptop with no USB boot option, you should try to make a bootable flash drive again. It takes a bit of doing which may be why you didn't manage it the first time, but it's doable
