21 Feb 2019 at 09:06 #1 V4NT0M V4NT0M Soldato Joined 18 Jan 2007 Posts 19,848 Location Land of the Scots Looking for a program like the snipping tool but which instantly saves the snapped area to a file.
21 Feb 2019 at 09:18 #2 Armageus Armageus Don Joined 19 May 2012 Posts 20,323 Location Spalding, Lincolnshire https://getgreenshot.org/ Depending on what you need Window Key+PrintScreen Key does the whole screen straight to the Pictures\Screenshots folder I've also seen reference to Windows+Alt+PrtScn capturing the active window to a file, but not working for me on Windows 10 - 1803.
21 Feb 2019 at 09:37 #3 Orcvader Orcvader Soldato Joined 11 Oct 2009 Posts 17,079 Location Greater London Armageus said: I've also seen reference to Windows+Alt+PrtScn capturing the active window to a file, but not working for me on Windows 10 - 1803. Click to expand... I believe you need to ensure you're signed into OneDrive for that, and also have the setting enabled: It's also either just prtscn (for the whole window) or alt+prtscn for the currently selected Window. I've been using it and it works well but can't snip areas with it.
21 Feb 2019 at 12:16 #4 V4NT0M V4NT0M Soldato OP Joined 18 Jan 2007 Posts 19,848 Location Land of the Scots Armageus said: https://getgreenshot.org/ Click to expand... This is perfect, thanks!
21 Feb 2019 at 12:26 #5 AHarvey AHarvey Soldato Joined 6 Mar 2008 Posts 10,092 Location Stoke area I've just put a request in to have this on all the work laptops. Cracking program, been using it for years now.
