- 6 Feb 2008
In our hall, the subfloor is asphalt/bitumen which was poured on a sand base with no insulation underneath.
We are about to have a new front door installed and the hall tiled at the same time. The person fitting the front door suggested that we should put down insulation boards before tiling. This sounds sensible however my issue is that this would raise the tiles considerably above the living room carpet meaning that we have a step.
The tiles are 12mm thick and I imagine adhesive is maybe 5mm thick? This 17mm is about right for the carpet but an additional 10mm of insulation board + a few mm of adhesive to stick them down would be too much I think.
Without insulation, will the hall tiles feel too cold/unbearable?
Just to add: We tiled the kitchen floor too but put down insulation boards + electric underfloor heating + a poured screed + the adhesive + 12mm tiles. This has left a noticeable step into the kitchen. We're trying to avoid the same for the hall to living room transition.
