My utility room is at the back of the double garage and has a breeze block wall with the internal wall dot and dab plasterboard. The garage side is just bare breeze block. The garage is pretty cold because of the way the garage door has been fitted and allows quite a draft into the garage. Longer term I will look to fix this but its a double electric roller door so imagine its not going to be cheap to get a correctly fitting one!
So, I was wondering if insulating the utility room wall would offer any benefit from the cold garage? And if so what would you advise?
Thanks
Thanks
