Hi folks,
I have an insurance claim for a new PC and monitor.
I need to submit a list of components I would need if I were to build it myself and a comparable prebuilt system. These should be between £800 and £1100
I was going to use a competitor to give a component list (so i have different suppliers) and use a OCUK prebuilt system.
The differences between all OCUK systems are a bit odd.
Does anyone have any opinions on prebuilt systems?
I would be using the system for lots of Photoshop and games.
Thanks
Thanks
) for crysis you're better off putting together you're own.
