- 4 Jan 2005
My case has three fans attatched to it. Theres an 80mm intake fan on the front to draw air in over the HD. Then there's another 80mm on the side panel blowing air out of the case, and finally a 120mm fan on the air also blowing air out.
I want to turn the 80mm on the side panel around so that it looks better and doesn't shine so much light into my case (it has blue LED's on it and its detracting from my UV look inside the case).
I hear somewhere that you should either have greater intake or greater outake but I cant remember which. Is it going to be less effective to have the fan drawing air in?
