Ladforce said:Hi all,
I was wondering how much this car costs to run ie servicing, fuel etc. Would it be a viable car for doing 30 miles each way to work in? How reliable are they also?
Thanks
Jestergt said:Try a search in this forum, im sure theres loads of info about them
mr_x_plosion said:very reliable cars, engines are bullet proof if looked after (serviced) seen one at 170,000 miles and still going strong
I'll explain for the UK model as I'm not sure if the imports are the same.Ladforce said:Hi all,
Thanks
Ideally you'd want a stock car, main things to look out for:Ladforce said:Thanks very much for all the advice, looks like a fairly economical car and also great fun at the same time. Now just need to find a decent one, is there anything in particular I should look out for apart from full service history essential? Also, would around 6k be enough to secure a decent one or do I need to up my budget a bit?
