Hey.
Am without a graphics card atm so I decided to use the onboard video for the time being. I get an output fine and can use Windows but when I install the driver for the VGA I get the following...
This is in Device Manager. There is a yellow exclamation mark next to the device. Aero isn't running.
I've tried chopping and changing a few things in the BIOS, disabling USB, LAN, parallel/serial ports, and fiddling with the graphics settings but nothing will make these damn drivers run.
Help!
This device cannot find enough free resources that it can use. (Code 12)
If you want to use this device, you will need to disable one of the other devices on this system.
Click 'Check for solutions' to send data about this device to Microsoft and to see if there is a solution available.
Help!
