Hello, I'm trying to make simple office PCs for general use. I have the Asus prime A520M-K motherboard and are having problems getting a simple 2 monitor setup to work using the onboard graphics. Everything works fine on either the VGA or HDMI port. Once 2 monitors are connected both monitors malfunction, flickering on and off. This happens regardless of the whether the IGFX setting is enabled or disabled in the BIOS. This also happens before windows has loaded and so is not a driver issue. This is not a one off hardware fault as I have 3 of these motherboards, brand new, and they all exhibit the same behaviour. Other Prime A520M-K boards purchased earlier this year worked normally on 2 monitors, so I know it should be possible and is not a chipset limitation.
Does anyone have any ideas?
Thanks,
Jamie
Thanks,
Jamie
