Integrated water cooling for graphics cards?
Caporegime
17 Jul 2010
I've got a reference EVGA 670 and I plan on getting a new case soonish and was thinking about improving the cooling of the card as it's starting to run rather warm with the warmer weather coming in recently. A couple of nights ago my room was getting very warm so I opened the door and cracked the window. Before that the card was apparently hitting 99'C :eek:
So this has made me consider that instead of going for a prefilled cooling solution for my CPU which currently sits under a Gelid Tranquillo and rarely hits higher than 50'C I might be better to cool the card better.
Does such a thing exist or will it end up being something that will be bodged from a CPU version and I'd be better off selling the 670 and buying a custom cooled 770?
99c ****. How high was the ambient? 50c? lol
Try giving your card a clean mate, Something doesn't sound right.
When I had 1 670 on air heavily OC'd it would peak around 65c, 70c if ambient was high.
Fan profile according to Afterburner was set for 100% so not sure whats up. Might check my fans and dust covers but ambient was probably 25'c.
if you have good airflow, a decent air cooler will be better than pre made water cooling, if they even exist. Only reason I bother with it is for looks, and space.
Single slot was my #1 reason for water cooling, and not I can't get that and have still not got round to updating my cards because of it.
Temps wise, with high static pressure fans it enables you to cool multiple cards/stuff much more effectively due to larger heatsinks (radiators) compared with air cooling.
So, single card/cpu, go for custom air. its a lot cheaper and just as good.
