Integrating Home Cinema into your Living Room...
14 Jul 2007
Hi folks, Im after a bit of help for what Im sure is a common problem....
I currently have two sitting rooms, one which is more decorative with less kit in it - 50 inch tv, skybox, no surround sound and another which has a smaller tv but has surround sound and my projector. However in the next few months my wife and I will be moving house and are expecting our first child. Exciting times but a shift in priorities.
Among other discussions we are trying to work out whether we need the two sitting rooms. In reality the projector is under used and indeed the second sitting room itself isn't used as much as it could be. That said I love the projector and I love a bit of tech so we are faced with a few choices. My wife doesn't want a room dominated by speakers and all that sort of kit at the expense of home homely features (hence the two sitting rooms in the first place) but at the same time would be willing and happy to compromise if we had to have everything in one room. She likes watching movies on the projector but also as I say, wants a room that looks as much like a conventional, family friendly sitting room as possible.
Is it possible to do both in the one room? Have you and your other half made this compromise and if so how? Could you post some pics to give me and idea of what it looks like and how it works in practice?
At the end of the day there will be some reno work going on in the new house so we have plenty of options, eventually I have a barn and an attic that could be converted into a more bespoke home cinema room but thats a fair way down the lien so this would be a medium term solution.....
.....or should I just buy a bigger tv, ditch the projector and surround sound and accept that the compromise isn't a practical one?
Have you looked at a "style" speaker set like monitor audio mass or q acoustics q7000
I have q7000i set, 5.1, as we had a similar issue as you where it is a main sitting room and parents didn't want big arse KEF or whatever speakers that isn't really main living room friendly
Take a look at richer sound site... it might be that your wife has a different idea about speakers - they don't all have to be big blocks you can get more discreet systems which sound good
Basically she doesn't want anything that means the overall feel of the room is dominated by tech, however id like to keep the projector, screen and surround sound too. If it can't be done then it will just have to go in a different room. I guess a screen can be quite discreet and projector placement might not be too bad either. The other issue is adding in Sky box, sub, amp, playstation etc and before you know it you have boxes everywhere!!
http://imgur.com/a/W12Ga
This is mine. Ignore the fact the amp is on a crappy table (will be replaced :P) and the speaker cables are exposed........ will be sorted when I can be bothered
and that the centre speaker is on the floor with a nice speaker cable effect
But I feel that they don't dominate the room at all, barely noticeable tbh and they sound fantastic
Almost all boxes (Sky, AV Receiver etc) should be controllable via either RF or Bluetooth meaning you can hide them behind a cupboard door.
Can you put the screen behind some sort of box on the roof. A sheet of wood painted the same colour as the roof, wall whatever to hide it? So no one would know it's there unless looking for it. And obviously the same with the PJ. It'll obviously take some extra work though.
I've seen pj's that hide in the roof and electronically come out, but I'd imagine the work/cost will be high.
This is mine. Ignore the fact the amp is on a crappy table (will be replaced :p) and the speaker cables are exposed........ will be sorted when I can be bothered
Where do the wires go from the speakers and from the tv and what happens to the cables if you want to change the equipment if the wires are going behind the walls and in trunking? This has puzzled me but if do-able would make a big difference to my options!
I can do any of this as the rooms will need work, redecorating etc anyway but I don't have a huge budget given the fact that i'll have a child by then! Happy to spend a bit of cash though for the right ideas if we are doing some work anyway.
Thanks for the replies everyone, keep them coming!
Lounge PJ setups dont really work for me. The wife friendly option would be a 55" (65" if you can) and a pair of speakers. Given that you've got a kid en route I assume a sub is out?
If you are ripping walls down and replastering then the wires will simply go through the wall and stick out wherever you want the speakers. If it's just paint etc then it will be almost impossible to hide the cables without some trunking or so
When changing equipment this is no issue as the cables will always be the same - just standard speaker wire for all speakers.
It was easy for us however as the part you see is a newly built extension so we just ran the speaker cable the day before the plasterer came and started nailing the plasterboards in
Wire goes through the wall and then into the amp, and then from the amp it is just 1 HDMI cable again behind the wall in a drain pipe up to the TV so once finished the cables will be invisible
That is an option but as I already have the projector id like to try and make it work if possible. I haven't ruled anything in or out at this stage though. Any reason you feel it doesn't work?
In my head Id be panicking at the prospect of a cable packing in and not being able to change it, I assume this isn't really likely though! We would be looking at replastering as part of an insulation upgrade so this could well be doable the more i think about it.
Ive seen the speakers mentioned above and they are very room friendly, are these recommended?
http://petertyson.co.uk/index.php/q-acoustics-q7000i-5-1.html
Those are the ones I have and although I am no sound expert they are really good and reviewers seem to think highly of them as well
You will need an amp to go with them - I went with Denon X2300W as they were on an offer at richer sounds for a package of the speakers and amp
Speaker cable is extremely simple, just two cables. Once they are in before plastering just give them a quick test with an electrical tester to make sure a signal or electricity is passing from one end to the other and all will be well. Once in the wall nothing is going to happen to them. It's the only way to get a clean look with no cables everywhere for wall mounted speakers.
Yeah amp isn't a problem, cheers for the recommendations. I think i'll probably go along these lines with hiding the wires, seems daft not to if we are replastering anyway. Will look into projector options too.
I was in the same boat as you a few years ago, it's amusing you think you'll have time to watch anything lol. I went from watching films on a big screen to watching them in bed on my phone with headphones on. You'll be worrying about not being able to hear the baby monitor while they are sleeping, tip toeing round trying not to wake them as you'll get so little sleep every second counts.
I'm ok now tho she's just turning 2 and life is returning to some normality, although the wife keeps dropping hints of another.....
Oh I'm well aware of the situation don't worry! However the renovation work is being done so I need to look at what is possible and not possible so than down the line I can watch Peppa Pig on a 120 inch screen!!!
If you're looking for inspiration you could look at some of the builds on AV Forums. https://www.avforums.com/forums/members-diy-home-cinema-showcases.152/
With the equipment hidden in a cabinet and a drop down projector screen If you're willing to spend a bit of time and money on a build don't see why you couldn't have a great working system. You could even go as far as in wall speakers / subwoofer if you want a totally clean look.
Thanks I will check that out. Spending money is relative I suppose. Ultimately the house is mortgage free so we will probably take out a small one for renovations a little of which may allow us to integrate the Home Cinema and do some nice things. The other side of that coin is that with a child on the way the days of spending cash on such frivolous things should probably be over!! Hopefully we find some middle ground somewhere!
Have you taken a look at in wall speakers?
You can get some where the speaker fabric can be custom printed and they basically become a picture frame. Monitor Audio do a range iirc.
We considered them when we moved, but with the layout in the lounge that we have ended up going with normal speakers.
if you bury the HDMI cable in the wall , be sure to use trunking and add 2 more cables , you can then use one of the cables to pull a new cable through should HDMI spec changes again !
