Integrating Power DVD into Vista MCE
9 Aug 2003
Liverpool
Is there a way I can integrate the version of PowerDVD that comes with the LG Blue-Ray/HD-DVD into Vista MCE? If I put a Blue-Ray disc in and try and play it in Vista MCE it says there is no program installed to play Blue-Ray drives, even though Power DVD is installed.
so with this, if you tell vista mce to use the powerDVD decoder for hd-dvd and/or blu-ray you should be able to play HD and BD movies using media center instead of powerDVD?
